For a long time my Minor has had a knocking noise. You may have heard it last summer. The car has been off the road since the summer rally
I (and others) have had the whole engine to bits over it and eventually discovered the problem.
The “Rear Main Journal Flange” has split open along the edge of its keyway. (its weakest point).
this is the machined centre piece for the flywheel that connects to the crankshaft.
It’s the original type (1929) which is parallel using a keyway rather than the later (and better) tapered kind.
My understanding is that many of the original engines will have the later type fitted when the crankshaft is renewed.
If this is so then hopefully there will be one of these obsolete flanges sitting on garage shelf somewhere.
Is there anybody out there who might be able to help.
I don’t want to replace the crankshaft because there is little wear on it. But I suppose I might have to if I can’t get this part.
