Brake cables
Brake cables
Does anyone know the length of the front & rear brake cables on the early Minor with the front cable going around the bottom of the king pin
Ewan
Re: Brake cables
Hi Ewan,
Good to hear from you.
You can find all the brake cable lengths for the OHC chassis at http://www.vintageminor.co.uk/tech/index.htm under Brake Cables. The change at M9249 was to shackle the pulley on the kingpin, hence reducing the required length by 1 inch. The change at M29528 was when the cables were re-routed to levers forward of the axle.
